z1000a1 cam end plugs
mirror man
#1 PostAuthor: mirror man » Sat Jul 23, 2011 5:20 pm
hello chaps help ive just fired up the motor after a rebuild, i fitted some new rubber cam end plugs[vesrah from z1 ent] fitted with a little gasget cement, i let the motor run for around 7 or 8 minutes, then noticed one plugs [no4 exhaust] had sucked in and was leaking oil , i took off the cover and fitted an old plug, started the motor and once again one of the new plugs started to suck inwards [no 1 exhaust] again replaced with old plug, started the motor now no 4 inlet is doing the same has any one else had this problem :?: have i done some thing to cause this problem :?: or could it just be very poor plugs :?: :?: :?: :?: thanks alan
#2 PostAuthor: PAULJAC47 » Sat Jul 23, 2011 6:23 pm
Hard to tell from your pics but you are fitting the plugs with the concave side to inside and the lip to the outside,i use RTv silcon and let it nearly cure b4 fitting cam cover,degrease hollows with carbs cleaner b4 fitting.
mirror man
#3 PostAuthor: mirror man » Sat Jul 23, 2011 10:10 pm
hi paul yes the plugs are in the right way, i did wipe clean but didn't degrease the hollows with carb cleaner, i thought the sealer was intended to prevent oil leakage not stick the plugs in position, i assumed the plugs would be held in under pressure, i think i may need to refix with a silicon sealant, is rtv a special sealant :?: can i pick this up from any bike shop cheers alan
tlc
International Rep
#4 PostAuthor: tlc » Sun Jul 24, 2011 5:44 am
RTV is room temperature vulcanising. Plain old silicone gasket to you and me.
I put mine in with a smear and let them go off before fitting the cam cover. When the sealant is in place you should see the plugs sitting just proud of the cover surface. The cover then will compress the plugs ever so slightly when fitted.
Good luck.
Asphalt Cowboy
#5 PostAuthor: PAULJAC47 » Sun Jul 24, 2011 8:25 am
Chris is right, Alan any Halfords stock RTv....Paul J
mirror man
#6 PostAuthor: mirror man » Sun Jul 24, 2011 9:13 am
cheers guys, halfords it is, thanks again alan
HowieD
#7 PostAuthor: HowieD » Sun Jul 24, 2011 9:24 am
If it's any help - I replaced mine with anodised ali ones from Ape via Debben's. They have a lip on both edges and slip over the width of the D (on its side) shaped hole. Sealed with a smear of Hylomar.
They wont suck in or blow out.
H :lol: wie
CD185, Maggot, Z1-R, Horace
mirror man
#8 PostAuthor: mirror man » Sun Jul 24, 2011 10:30 am
hi howie i did buy some ali one's via e bay a little while ago they looked the part but didn't fit so sent them back, that put me off so i thought i would stick to the rubber type, even that may not be straight forward for a novice
alan
HowieD
#9 PostAuthor: HowieD » Sun Jul 24, 2011 10:49 am
Alan,
true mine didn't fit straight off either - I took a smooth flat file to the end of the head to reduce the thickness of the D Holes.
Didn't take too long and a bit of careful preparation with oily rags to catch the filings etc.
Regards
Howie
#10 PostAuthor: Pigford » Sun Jul 24, 2011 2:57 pm
Same here with the alloy plugs, bit of fettling but once done are no trouble :wink:
The rubber ones are prone to moving and need to be thoroughly set (with goo) before running the motor :??
mirror man
#11 PostAuthor: mirror man » Sun Jul 24, 2011 6:13 pm
thanks mark, i've just re fixed the plugs with some silicon sealant, i'll test the motor tomorrow and see how it goes
alan
