By pass the side stand cut out switch - which wires
Z1000R2, or at least it will be when i put all the bits back together. I cut the wires behind the side panel as the switch wouldnt go through the hole in the foot peg holder.Tried to start the bike + nothing,joined the wires together again and it fired up ok.Could just shorten the wires and rejoin them and just leave the switch behind the side panel but its untidy so i would like to bypass it.
i believe the 2 black wires would be joined together.The clutch lock out switch on a kwaks are just 2 black wires to a switch remove switch join 2 blacks...hey presto! so would imagine it would be the same as...but,perusal of a W.D. would confirm,hence.Bugger i know about the other 2 wires need W.D.
