By pass the side stand cut out switch - which wires
Plumba 54
#1 PostAuthor: Plumba 54 » Wed Jun 28, 2006 7:10 pm
i want to bypass the side stand cut out switch, there are 4 wires, 2 black, 1 green/white and 1 blue/white. Which ones will have to be joined to enable this,or am i way off track?
#2 PostAuthor: Pigford » Wed Jun 28, 2006 7:13 pm
What bike is it for..... My Gixxer had one of them, I just removed it and it was OK... It must have just earthed the ignition low tension side?
Plumba 54
#3 PostAuthor: Plumba 54 » Wed Jun 28, 2006 7:17 pm
Z1000R2, or at least it will be when i put all the bits back together. I cut the wires behind the side panel as the switch wouldnt go through the hole in the foot peg holder.Tried to start the bike + nothing,joined the wires together again and it fired up ok.Could just shorten the wires and rejoin them and just leave the switch behind the side panel but its untidy so i would like to bypass it.
Plumba 54
#4 PostAuthor: Plumba 54 » Thu Jun 29, 2006 9:39 pm
dont anybody know?
#5 PostAuthor: chrisNI » Thu Jun 29, 2006 10:33 pm
Mine doesn't have one. At all. I'll take a look at the wiring diagram tomorrow and try and see what's not there.
Ed Z1-R
#6 PostAuthor: Ed Z1-R » Fri Jun 30, 2006 2:07 am
i believe the 2 black wires would be joined together.The clutch lock out switch on a kwaks are just 2 black wires to a switch remove switch join 2 blacks...hey presto! so would imagine it would be the same as...but,perusal of a W.D. would confirm,hence.Bugger i know about the other 2 wires need W.D.
#7 PostAuthor: Rich » Fri Jun 30, 2006 4:18 pm
Just do a conductivity test on the switch. A battery and a bulb will do if you don't have a multimeter.
Plumba 54
#8 PostAuthor: Plumba 54 » Fri Jun 30, 2006 8:25 pm
Thanks to all, will have a play Saturday.If the powder coaters get their fingers out i might even be able to ride it to Mallory
#9 PostAuthor: Pigford » Fri Jun 30, 2006 8:26 pm
Pumba 54... just cut the bloody stand off!!!!
Plumba 54
#10 PostAuthor: Plumba 54 » Fri Jun 30, 2006 8:33 pm
would do but you cant always find convenient trees to lean your bike against and car drivers get the cob on when they find your bike resting on their cars
Plumba 54
#11 PostAuthor: Plumba 54 » Sun Jul 02, 2006 8:18 pm
the 2 black ones its is, cheers to all
Plumba 54
#12 PostAuthor: Plumba 54 » Tue Jul 11, 2006 8:46 pm
logging in
Big John
#13 PostAuthor: Big John » Tue Jul 11, 2006 9:20 pm
Dale is the Z1000R up and running now?
Plumba 54
#14 PostAuthor: Plumba 54 » Tue Jul 11, 2006 9:32 pm
Sunday barring any further unforseen problems (keeping everything crossed)
Any luck with the side panel?
Big John
#15 PostAuthor: Big John » Thu Jul 13, 2006 8:06 pm
No luck with a side panel yet but it looks like Chris has a badge.
