i`ve eventually received the log book through the post for the frame now. happy days. i can go hammer and tongs at the frame now not having to think about getting it re registered. i`ve been making the cooler mounts over the weekend. they have come out ok. time they are coated, they will look good. i want to make some spacer tubes to fit between the top and bottom flanges, but this can wait until i get a motor for my lathe. no rush there. i have used the rubber mounts from the bandit oil coolers. the same as i did for my bandit. i haven`t had any problems with them at all.
so, getting back to setting up the rake, trail, ride height, etc, etc. i have been trying to get the bike sitting so it looks right. because the aprilia forks are alot lower than the standard zed ones, to get the rake angle right, i need to drop the back of the bike down and it looks shite. i am over six feet tall, and it needs to not feel as if i`m riding a fizzy. so, i have slid the forks through the botom yoke by about 60mm. raised the rear so the swing arm angle is about 8 degrees and the rake is 25 degrees. all is looking good now. so, i need to sort out the short fork problem.
as i see it, i have 3 options.
1. massive stepped yoke.
2. extension slugs screwed into the tops of the forks.
3. longer stanchions.
the problem with 1 is the yoke will look shite against the standard bottom yoke. i am trying to keep the look "factory".
the problem with 2 is a lack of strength (possibly) by adding an extra "screwed in" part to the top of the forks. and the problems with extending the adjusters, etc.
so, now for 3. there is a company called all bike engineering. they make after market stanchions, discs, etc. they can also make stanchions that are a bit longer than standard. maybe this is the way to go. here are their web site.
http://www.allbikeengineering.co.uk/index.html
have any of you lads had any experience of getting round this problem. i am looking forward to hearing your views and opinions on this.............
