z1b float level
wallopp
z1b float level
#1 PostAuthor: wallopp » Mon Apr 16, 2007 3:32 pm
can any one help me i have a z1b which keeps flooding i have changed float valves and seats i can borrow a tool to measure float height not fuel height but i dont know what it should be ??? thanks steve
#2 PostAuthor: paul doran » Tue Apr 17, 2007 5:00 pm
can anyone answer this
#3 PostAuthor: Pigford » Tue Apr 17, 2007 7:59 pm
Most Mikuni carbs are somewhere between 17 - 20mm float height :!: :?:
The Haynes don't say, they only recommend using level gauge.
I'd guesstimate 18mm with float bowl removed, measuring from bowl gasket face (carbs inverted) to bottom of float as it just touches valve.
#4 PostAuthor: Pigford » Tue Apr 17, 2007 8:03 pm
PS, If this causes flooding (too much fuel in bowl & too rich) increase this figure a couple of mm. :wink: Hopefully this shouldn't be too far out :?:
Hobbo
float height
#5 PostAuthor: Hobbo » Tue Apr 17, 2007 9:02 pm
HI THERE
Z-POWERS BOOK SAYS 23MM FROM AS PIGFORD SAYS THE GASKET FACE CARBS UPSIDE DOWN
PHIL
Bruce Sexton
#6 PostAuthor: Bruce Sexton » Wed Apr 18, 2007 12:42 pm
I'd agree with the 23mm. I've always used this measurement with no problems :)
Why were Z1A's not Blue???????
wallopp
z1b float level
#7 PostAuthor: wallopp » Thu Apr 19, 2007 3:32 pm
Thanks a lot guys i'll try that and see how it go's thanks
Bruce Sexton
#8 PostAuthor: Bruce Sexton » Mon Apr 23, 2007 12:24 pm
This months CMM has a bit on setting float heights.
Bruce
