AbuZed 1
#31 PostAuthor: paul doran » Tue Jan 13, 2009 11:08 pm
Gus it is certainly going to be different
jus1975
#32 PostAuthor: jus1975 » Thu Jan 15, 2009 6:59 am
Where did the swingarm come from?
All About Accessories
www.tripleaperformance.com
Gus
#33 PostAuthor: Gus » Thu Jan 15, 2009 12:43 pm
VFR 750
"Set the GRINDER on it"
tracktime
Wow! That looks serious!
#34 PostAuthor: tracktime » Sun Jan 18, 2009 8:46 pm
Nice bike man! I can't wait to see it finished.
What kind of forks are you running?
Gus
#35 PostAuthor: Gus » Mon Jan 19, 2009 10:51 am
Hi.
I'm using ZX9R B4 forks with a CBR wheel to match the rear.
The problem at the moment is getting the discs and calipers to match up.
tracktime
Forks
#36 PostAuthor: tracktime » Mon Jan 19, 2009 9:54 pm
Hey thanks for the info. I may be buying a set from a 636 zx6 for mine.
I think they will be tall enough.
I wonder if the zx9 and cbr rotors have the same offset.I wonder if they can be switched. anyway best of luck! Thanks again. Chad [/img]
Gus
#37 PostAuthor: Gus » Tue Jan 20, 2009 9:05 am
Hi Chad.
I would check the height of the 636 forks as I would think they will be shorter than the ZX9R B4 by an inch or maybe 2.
I'm led to believe the longest forks are
ZX9R B4 (USD)
ZX9R C2 (RWU)
GSXR 1100 L or M (USD)
Other people may know some more and could add to the list for everyones benefit.
Unfortunately for me the CBR rotors are 296mm dia. 3.5mm inboard and 6 hole mounting and the ZX9R are 320mm Dia. and 5 hole mounting.
Gus
tracktime
You are correct Gus.
#38 PostAuthor: tracktime » Tue Jan 20, 2009 10:02 pm
I should go with the zx9. If don't I will get something simular.
it's too bad because I found a good deal on Ebay for 636 stuff.
Thanks again.
tracktime
How is your bike coming along?
#39 PostAuthor: tracktime » Sun Feb 01, 2009 2:16 am
I took your advice and bought zx9 usd forks. I have to figure out the top yoke. I did not get that part.
ludders
#40 PostAuthor: ludders » Sun Feb 01, 2009 9:42 am
z1a , z900 a4 , zx9r
Gus
#41 PostAuthor: Gus » Fri Feb 13, 2009 9:47 am
Hi.
Does anybody have a "530, 18 tooth, 13 spline, 15mm(5/8 inch) offset," front sprocket to fit the Z1, Z1A, Z1B, Z900, Z1000A1/4, H, and Z1R that I could borrow to set my chain alignment on my project.
I am waiting for Debben to recieve a new batch from their suppliers but that is 4 or 5 weeks away.
This is major hold up time.
Gus
#42 PostAuthor: Gus » Sat Feb 27, 2010 3:11 pm
Well it's been a year so here is an update of progress
Very slow progress
#43 PostAuthor: Ginger Bear » Sun Feb 28, 2010 10:00 am
Some serious frame mods there Gus...... Did you get your sprocket from Debben in the end :?
# 104
Gus
#44 PostAuthor: Gus » Sun Feb 28, 2010 2:30 pm
Hi GB
Yes my metallurgist guru Martyn has done some damn fine handy work on the bike.
The tube mounting for the shock mount under the frame.
Replaced the missing rear frame section.
Reworked the rear side rails
Altered the rear brake pedal arm.
Offset the kickstart and reworked the angles on it to clear the footrest.
And all the other bits I've forgotten
His work is amazing, check this build he did http://www.sunbeamspecial.co.uk/img/hereitis/1.html
He's going to do the exhaust for me and then some front disc carriers to mate the Ducati discs to the h***a wheel in the Kwak forks
Yes I got the sprocket from Debben after Talon had made them another batch.
Hopefully the next update will be a bit less than a year
Gus
#45 PostAuthor: Gus » Fri Dec 02, 2011 9:45 pm
Update from the meltdown.
This is about where I'm at at the mo.
Extremely slow progress I'm afraid
Users browsing this forum: Bing [Bot] and 17 guests
