Just some basic info please
uk kev
#1 PostAuthor: uk kev » Sun Apr 15, 2007 6:39 am
I just need some basic Z1000 info please, as I don't have a service manual at this time, I am sure the info is on this site somewhere but I can't find it.
Which Denso plugs.
Plug gap size.
Tyre pressures.
and do you need to re-jet to use pod filters?
london calling
#2 PostAuthor: london calling » Sun Apr 15, 2007 8:25 am
DENSO W24ES-U,gapped at 0.7mm.
The Platinum plugs are W24ES-ZU
The Iridium plugs are IW24.
Jack
#3 PostAuthor: Pigford » Sun Apr 15, 2007 9:43 am
Tyre pressures are: 26 (f) 31 (r) or 26/36 with pillion.
As for jetting, go up 10% on mains to start with to be safe. Is that with a 4-1 pipe too :?:
uk kev
#4 PostAuthor: uk kev » Sun Apr 15, 2007 11:06 am
yes 4-1 pipe, does that change things?
#5 PostAuthor: Pigford » Sun Apr 15, 2007 4:55 pm
If its a 4-1 as well as hi-flo filters, this can lean things out a tad more, but I'd still think 10% increase should be a good starting point :wink:
The 4-1 should be less restrictive, so in theory, allow more mixture to flow, therefore an increase in fuel & air must be catered for :|
