gpz1100 a2 discs
marve114
gpz1100 a2 discs
#1 PostAuthor: marve114 » Thu Feb 04, 2010 6:32 pm
hi all has any one got a set of these discs
i mainly after the front at the moment but cannot be no larger that 170mm
as im using the wheels for my z1000j
but most of all i dont want to pay the earth for them as im a poor student :D
let me know cheers
lee
marve114
#2 PostAuthor: marve114 » Thu Feb 04, 2010 6:33 pm
i think gpz750 a2 discs are the same :?:
london calling
#3 PostAuthor: london calling » Thu Feb 04, 2010 6:57 pm
GP ZX 1100 front discs are 280mm diameter,so are 750 TURBO.
The GP ZX750 uni-trak front discs are 270mm diameter.
These discs are a 6 bolt mounting,wheres the 1000J,etc are 7 bolt fixing.
I might have some 270mm discs,I'll check on saturday and let you know.
Jack
marve114
#4 PostAuthor: marve114 » Thu Feb 04, 2010 7:20 pm
im putting gpz1100 wheels on my j3as they go straight in so i would need some gpz750 discs by the sounds of it
cheers
london calling
london calling
#5 PostAuthor: london calling » Thu Feb 04, 2010 7:28 pm
The J3 runs 280mm discs as standard,same as the 1000R2 Lawson and GPz1100B2.
The J1/J2 run 270mm front discs.
The fork bottoms on the J3/R2/B2 are slightly different and has the lower caliper mount offset to allow for the larger disc.
Jack
marve114
#6 PostAuthor: marve114 » Thu Feb 04, 2010 9:01 pm
hmmm will have to drop the wheel out now and make sure of the size
#7 PostAuthor: Pigford » Thu Feb 04, 2010 9:36 pm
You don't have to take the wheel out to measure the disc diameter.... :??
marve114
#8 PostAuthor: marve114 » Fri Feb 05, 2010 5:56 pm
checked my discs they are to small :shock: at 270mm
i removed the caliper to find this !
280mm needed please :beer
steve.w
#9 PostAuthor: steve.w » Sat Feb 06, 2010 7:03 pm
i may have soom mate if u still need some ill have a look tmmrw steve
marve114
#10 PostAuthor: marve114 » Sat Feb 06, 2010 7:18 pm
yeah im still after a set of discs must be off a gpz1100 a1-a3
6 bolt fitting and diameter of 280mm
let me know
land_rover4x4@hotmail.com
07515553478
lee
marve114
#11 PostAuthor: marve114 » Sat Feb 06, 2010 8:51 pm
london calling
#12 PostAuthor: london calling » Sun Feb 07, 2010 9:34 am
Yes they will :wink:
Jack
marve114
#13 PostAuthor: marve114 » Sun Feb 07, 2010 9:54 am
hope your right lol :lol:
london calling
#14 PostAuthor: london calling » Sun Feb 07, 2010 10:03 am
Just check that the PCD is the same as your existing disc/wheel.
Jack
steve.w
#15 PostAuthor: steve.w » Sun Feb 07, 2010 3:40 pm
hi mate ive got a good pair steve
