z1000a1 Start of the uphill struggle !
- ade woollams
i bet its got a yellow back axle with a fog light under there to light it up as well.
- paul doran
tm53chev
proper build
in order to do a proper build you need a frame off disassembly or buy it already disassembled if you want a challange
Rob Lafferty
- Regular Poster
Thought it was time to update the project listing.
Project seems to be going backwards as things are still in the process of being dismantled, which has been a bit slow due to the weather and lack of garage space.
Some parts are are with RD Cox for cleaning and hope to be getting them back next week, when i will drop of more.
Engine has been dismantled with only a coulpe of screwhat have caused major problems. Two screws in the primary drive cover would not undo and had to be drilled. Still need to sort this out before all the engine bits go off for cleaning.
Carbs are away being ultrasonically cleaned and then vapour blasted by keefleaf.
Rob Lafferty
- Regular Poster
Rob Lafferty
- Regular Poster
Rob Lafferty
- Regular Poster
Users browsing this forum: Bing [Bot] and 8 guests
