z1000a1 Start of the uphill struggle !
ade woollams
#16 PostAuthor: ade woollams » Fri Oct 16, 2009 3:18 pm
i bet its got a yellow back axle with a fog light under there to light it up as well.
#17 PostAuthor: paul doran » Sat Oct 24, 2009 7:44 pm
tailiftchris wrote:
Rob Lafferty wrote:Do also have a car - but you gessed it - its in bits on the drive
:shock: :lol:
so Rob is in truth Onslow :lol: :lol: :lol: :lol: :lol:
tm53chev
proper build
#18 PostAuthor: tm53chev » Tue Nov 03, 2009 10:23 pm
in order to do a proper build you need a frame off disassembly or buy it already disassembled if you want a challange
Rob Lafferty
#19 PostAuthor: Rob Lafferty » Sat Jan 16, 2010 3:53 pm
Thought it was time to update the project listing.
Project seems to be going backwards as things are still in the process of being dismantled, which has been a bit slow due to the weather and lack of garage space.
Some parts are are with RD Cox for cleaning and hope to be getting them back next week, when i will drop of more.
Engine has been dismantled with only a coulpe of screwhat have caused major problems. Two screws in the primary drive cover would not undo and had to be drilled. Still need to sort this out before all the engine bits go off for cleaning.
Carbs are away being ultrasonically cleaned and then vapour blasted by keefleaf.
Rob Lafferty
#20 PostAuthor: Rob Lafferty » Sat Jan 16, 2010 3:56 pm
also have new pair of shocks on there way.
Swingarm has been rebuilt with new parts and head bearing have been installed on the frame. Centre stand has been installed.
Stainless bolt kit will be ordered this afternoon witha a few more parts, hopefully.
Just need to decide on a colour scheme.
Rob
Jumbo
#21 PostAuthor: Jumbo » Sat Jan 16, 2010 6:25 pm
Good Luck with the build Rob. You look a bit tight on space which will make it awkward :roll:
I have just had a 10 x 6m garage built and as I move my stuff in which includes 3 bikes and the usual boxes of parts it is looking smaller by the day !
LE to JOG on a z900
P.U.M.
Rob Lafferty
#22 PostAuthor: Rob Lafferty » Sat Jan 16, 2010 6:36 pm
Oh how i wish :D
I could get the car in there as well.
Rob Lafferty
#23 PostAuthor: Rob Lafferty » Sun Jan 24, 2010 10:01 am
Managed to do more work to the bike so i thought it time for a couple of pics. Parts arriving and engine being sent off for cleaning.
#24 PostAuthor: Ginger Bear » Sun Jan 24, 2010 4:20 pm
That's taking shape now Rob. Looks good.
# 104
GUYZED
#25 PostAuthor: GUYZED » Sun Jan 24, 2010 5:40 pm
Looking good Rob - keep the pics coming :snap
#449
Z1000A2 Z650B1
Keefleaf
#26 PostAuthor: Keefleaf » Sun Jan 24, 2010 8:33 pm
Keefleaf
Robs' Carbs
#27 PostAuthor: Keefleaf » Sun Jan 24, 2010 8:44 pm
Keefleaf
Robs' CLEAN Carbs
#28 PostAuthor: Keefleaf » Sun Jan 24, 2010 8:49 pm
Keefleaf
Robs' CLEAN Carbs
#29 PostAuthor: Keefleaf » Sun Jan 24, 2010 8:50 pm
Keefleaf
Robs' CLEAN Carbs
#30 PostAuthor: Keefleaf » Sun Jan 24, 2010 8:51 pm
