Harris magnum Z1100R
Jappen
#16 PostAuthor: Jappen » Sun Dec 06, 2009 8:10 pm
Hei Rod :D
Dette blir nok bra :!: :D
Hilsen Jan Petter
80-Z1000H
79-Z1000MK2
Magnum1
#17 PostAuthor: Magnum1 » Mon Dec 07, 2009 6:42 pm
Hei Jan,
Tusen takk,
Jeg vil sende bilder naa sylinder hode er ferdig.
Har det bra! God jul!!
Rod :wink:
Jappen
#18 PostAuthor: Jappen » Mon Dec 07, 2009 10:47 pm
Takk, det samme til deg Rod :!: God Jul :!:
80-Z1000H
79-Z1000MK2
#19 PostAuthor: paul doran » Mon Dec 07, 2009 11:57 pm
ggod cpnversation lads?
Jappen
#20 PostAuthor: Jappen » Tue Dec 08, 2009 9:26 pm
Yes Paul..... :D Happy X-mas (God Jul) to you to :!: :!: :D
80-Z1000H
79-Z1000MK2
Magnum1
#21 PostAuthor: Magnum1 » Wed Dec 09, 2009 8:04 pm
Yep, welcome to the Norwegian sub - forum Paul - God Jul!
Rod :wink:
Magnum1
Back from South London
#22 PostAuthor: Magnum1 » Sat Jan 09, 2010 8:18 pm
Right! Thanks for all the support lads. Got my head back and I'm really pleased. All cleaned up and the crack is welded with new thread etc.
John at I KLEENZ MACHEENZ (daft name) is a top bloke. He is dedicated and really tries to accommodate is customers. Total cost for the welding and cleaning of rotten ol head and cam cover was £150, which I reckon is good value. If only he did human heads! Degreased and vapour blasted with optional finish (ready for paint or just ready). I've decided not to paint it.
hillbilly
#23 PostAuthor: hillbilly » Sat Jan 09, 2010 8:25 pm
well worth the worrying this morning. :wink: lam the nao de den london.
#24 PostAuthor: Al » Sat Jan 09, 2010 9:45 pm
Rod does the cam lobe clear the head where its been welded. they're pretty close there with GP cams in??
Just a thought before you assemble it.
Magnum1
#25 PostAuthor: Magnum1 » Sat Jan 09, 2010 10:13 pm
zorded wrote:Rod does the cam lobe clear the head where its been welded. they're pretty close there with GP cams in??
That's a good point Zorded, I will give that special attention on re-assembly. Might have to get the Dremel out!
Thanks,
Rod
#26 PostAuthor: Ginger Bear » Sun Jan 10, 2010 11:58 am
Be sure to give all the oilways a good flushing/blast too, as any blasting media left in there will soon make mincemeat of your cam & bearings. :shock: :shock: I know! :bawl :bawl
I think that's what the label is trying to say. :shock:
# 104
Magnum1
#27 PostAuthor: Magnum1 » Sun Jan 10, 2010 1:04 pm
Thanks Steve, I need to be reminded at my age mate!
Rod
Big Fluff
#28 PostAuthor: Big Fluff » Tue Jan 19, 2010 9:21 am
That's a nice looking Magnum you have there Rod, and I'm keen to see the end result.
I could never get on with Magnums, as they spent far too much time on the back wheel due to the ridiculously short (14") and steep raked swing arm.
In the 80's the alternative Moto Martin's allowed you to get on with 'the business' whilst the Harris's just spent their time being hooligans wheelying everywhere.
The swing arm in yours looks much longer than a conventional Magnum 2 offering though... Is that a Magnum 3 arm or a special from Harris ?
Keep up the good work, it's gonna look real good.
Will
Magnum1
#29 PostAuthor: Magnum1 » Tue Jan 19, 2010 7:51 pm
Hi Will,
Thanks for the comments. This is the fourth rebuild for Esmerelda. She's had all kinds of different paint and running gear etc. It's not actually a rebuild, I cracked the head and had to get it welded. Which meant a clean up an all that.
The swingarm was made by Polygon to enable the wider rim. They also did the yokes and some other bits and pieces.
Not much spare time at the moment, so it's going to be a while. Also, now I've cleaned up the top end, the rest of the motor looks even crappier!
Rod
#30 PostAuthor: paul doran » Tue Jan 19, 2010 7:55 pm
I wish I could get cracking on My Harris :oops: :oops: :oops:
Users browsing this forum: Bing [Bot] and 12 guests
