throttle push/pull
throttle push/pull
as the throttle is a push pull cable operation does it mean that the throttle has to be manually pushed closed or should it return by itself? mine sticks open, where is the best starting point to remedy this?
Steve Cooke
Steven Cooke wrote: if there where no closing cable fitted the vacuum of the engine will cause the slides to hang up for a second or two.
excellent - I wondered about this.
The carbs have a pretty strong spring and snap shut bet with engine running, when throttle released, the engine would run much faster requiring the final bit of twist to drop the speed to idle.
that exaplains why.
