Z1R Differences.
PhilZ1R
Z1R Differences.
#1 PostAuthor: PhilZ1R » Sat Mar 17, 2007 4:05 pm
Hi guys I'm hoping you can help me with some questions on my Z1R, I have just bought a German import Z1R MK2, its on an S plate 1978.
Whats the difference between MK1 and MK2? and why is my '78 model a MK2 or is that wrong :? , maybe its just the wrong badges.
I've bought to add to my little collection, I always liked them so now I'm a happy chappy :P ..
Its done 55k km, anything I should look for, should i be doing a full engine rebuild of just top end?
Thanks for you help in advance. Phil
phil churchett
#2 PostAuthor: phil churchett » Sat Mar 17, 2007 5:23 pm
Rather than try to explain the differences, it may be easier to look on Z Powers web site, [look under links section]. The model recognition section is what you need, can't remember if they list engine/frame numbers or not, but it is always worth giving them a call if you are un sure.
It may be that someone has fitted the incorrect badges.
There is also a good DVD which is available [also from Z Power], which has a section on the Z1R.
phil churchett
#3 PostAuthor: phil churchett » Sat Mar 17, 2007 5:28 pm
Further to the above, look under "model history Z1-Z1000".
ROZZER
#4 PostAuthor: ROZZER » Sat Mar 17, 2007 10:00 pm
Phil, any requirement to rebuild motor would depend on whether there are any nasty noises/evidence of burning oil. Bottom ends are bullet proof, top ends do wear, any history on bike? Any evidence that motor has been recently stripped (new gaskets/rtv around joints).
I would certainly check valve clearances and clean out carbs/balance them, check timing, but if no evidence of trouble as stated above, just leave it and enjoy riding. :P
AKA John Roscoe. PUM #028
1975 Z1B, 2013 Z800
Re: Z1R Differences.
#5 PostAuthor: chrisu » Thu Mar 22, 2007 1:40 pm
PhilZ1R wrote:Hi guys I'm hoping you can help me with some questions on my Z1R, I have just bought a German import Z1R MK2, its on an S plate 1978.
this is a MK2 Z1R
#6 PostAuthor: chrisu » Thu Mar 22, 2007 1:42 pm
not sure what model this one is though................... :)
