H**** oil cooler question
02GF74
#1 PostAuthor: 02GF74 » Sun Oct 11, 2009 8:39 pm
.... see photo ... looks like the fittings are cricular ends that bolt on using two bolts onto the cooler, an o-ring making the seal.
is that correct? as the fittings for the hjoses to clamp to the cooler available?
#2 PostAuthor: Rich » Mon Oct 12, 2009 5:20 pm
Basically yes, they are flanged to match the cooler with two bolt holes, the tube does extend in to the cooler fittings slightly to positively locate the o-ring.
Have a look for the hoses as well, the hose is usually swaged on and can be removed and replaced with the careful use of a hacksaw.
FER
Auld Heedyun
#3 PostAuthor: FER » Mon Oct 12, 2009 7:16 pm
Try gpz oilcooler hoses .
fer
