running rough
- paul doran
breakdown wrote:Hi, since the bike runs fine above 2k then mechanicly the engine should be sound, so that leaves the fuel system and the ignition system.
If your 100% sure that the carb is clean and ok, then the problem has got to be in the ignition system. When you say running rough does it backfire/ pop?
when the revs start to drop it backfires and pops
breakdown
Right, On the earlier Zeds the advance unit is fully opened by 3k starts opening about 1.5k,( not sure with the elr anybody else know). If you connect a strobe light and check the timing marks with that. If the marks are erratic when the problem appears then it's definatly the timing that is stuck on full advance. if the strobe shows the marks are fine them it's recheck carb time.
- paul doran
- paul doran
Check float heights now there off, pilots, and while you are at it check balance the old way. Was there any shite in the bowls ?
Good news you isolated it, It is nice to be able to take another set off the shelf so to speak and swap them over.
Sorted ready for winter.
Baza
- paul doran
