02GF74 wrote:nice welding - TIG or MIG?
how come the piccies in the early posts are not visible?
TIG.
Kwakanut wrote:Pasc, here is the response I got from the machinist....
"I retained the original shock tabs and left them in the original position. I ran a die over them to clean them up and to run the threads to the shoulder. then machined appropiate spacers, then machined special long sleeve shock nuts that fit inside the upper shock sleeve and to the appropiate length so that the shock stays put while allowing upper eye body clearence, the steel shock sleeve is slightly wider than the rubber bushing and shockbody eylet allowing movement
with out binding.......will send pic of what the shock nuts look like, you can see how I taper bored the outside of shock nut to the stud area so that there are no un sightly threads showing, the threads do go the width of the shock sleeve ......"
If you look at the 2nd to last pic in my last post with pics you can see what he's talking about with the threaded nut.
