switchgear help
switchgear help
Does anyone know if there is such a thing available as a switchgear internals repair kit for the z1000 a3/a4 ?
Ed, the starter button packed up. On stripping the switch I found the non metalic insulator that surrounds the starter button contacts had fallen apart in places allowing the contacts to short out against each other. It's basically just the piece that the wires attatch to that requires replacing. Everything else is fine.
