trick z1000
brian 450
#361 PostAuthor: brian 450 » Sat Aug 15, 2009 8:49 pm
#362 PostAuthor: Ginger Bear » Sat Aug 15, 2009 9:20 pm
Thank's Brian, I'll sleep a lot better tonight!
brian 450
#363 PostAuthor: brian 450 » Tue Aug 18, 2009 11:06 am
Made a bit more progress today, I have taken a 45mm x 30mm piece off billet to have a chanel milled through the centre of it. Then i will be able to shape it to fit in the swingarm. And get it tig welded in. The rear peg brackets are welded on now so apart from welding a mount for chain tensioner its done finally!!!!!!!!! :xbou
brian 450
#364 PostAuthor: brian 450 » Wed Aug 19, 2009 9:14 pm
Had the piece of billet milled today, Got to cut it to shape to fit in the swingarm now, Then get it tig welded in.Image
brian 450
#365 PostAuthor: brian 450 » Thu Aug 20, 2009 5:01 pm
MAKING A BIT OF PROGRESS NOW!!!! Finished the chain tensioner today going to fit it to the frame tonight very pleased with how nice and small it has turned out!!!! :D :D Image
#366 PostAuthor: Ginger Bear » Thu Aug 20, 2009 7:59 pm
After a bit of a 'lull' it seem's there is no stopping you now Brian!...... Keep it up :D
wierac21
#367 PostAuthor: wierac21 » Fri Aug 21, 2009 4:28 am
looking real good brian. Keep up the crafty work as I am looking forward to seeing it done :D
brian 450
#368 PostAuthor: brian 450 » Sat Aug 22, 2009 4:49 pm
Spent the today shaping the piece of billet i had milled the other day Image
brian 450
#369 PostAuthor: brian 450 » Sat Aug 22, 2009 4:51 pm
brian 450
#370 PostAuthor: brian 450 » Tue Aug 25, 2009 8:09 pm
Finish the chain tensioner now :D :DImage
brian 450
#371 PostAuthor: brian 450 » Tue Aug 25, 2009 8:10 pm
brian 450
#372 PostAuthor: brian 450 » Tue Aug 25, 2009 8:11 pm
brian 450
#373 PostAuthor: brian 450 » Tue Aug 25, 2009 8:15 pm
The bolt will be replaced with a allen bolt, going to get the billet chanel welded in on thurs then it's done :D :D
GUYZED
#374 PostAuthor: GUYZED » Tue Aug 25, 2009 9:01 pm
Very neat job that brian - keep the pics coming
#449
Z1000A2 Z650B1
brian 450
#375 PostAuthor: brian 450 » Tue Aug 25, 2009 9:11 pm
Thanks Guy. Will do!!!!
Users browsing this forum: Bing [Bot] and 7 guests
