I must say that with the needle set at the lower position the problem was much better I alterd the needle as that was what the manual said was the correct position.
The bike is standard in all aspects with new Dyna s new coils/leads/plugs/air filter.
My questions are:
1 What is the correct needle jet position.
2 The manual claims a height of 22cm of mercury should be achieved when balancing the carbs but at what revs is this at
3 What else could cause the problem as the bike runs well above these revs
4 The pilot air screws are set at 1,1/2 turns 1/4 turn out more than standard would this make a huge differance.
Any ideas would be helpfull as this is spoiling a good bike.
