has anyone got the following bits
engine bars.(crash bars)
footrest washer caps x 4 .(chrome ones that go under the bolts on the front footrest holders, curve at edges)
rubber drain pipe holder .. the rubber bit that you feed the overflow pipes off the carbs through.
a few last bits needed
