Offset drive sprockets
mayhem
#1 PostAuthor: mayhem » Sun Jul 19, 2009 5:09 pm
Hi,
Wondered if anyone out there can help. I have a B1 GPz1100 chop which I have just hardtailed and during this we fitted a rear wheel off a ZZR1100 rear wheel. I now have the problem of lining up sprockets etc. Some of the adjustment will be taken up by machining down the outer face off the sprocket carrier/cush drive at the back end but due to the width of wheel etc Iwill need to make up some of it at the front sprocket as well. Does anyone out there know of an easy cure or perhaps supplier of offset sprockets for these beasties. I will be puttin pics of the rebuild etc on site for anyone thats interested
Mayhem
phil churchett
#2 PostAuthor: phil churchett » Sun Jul 19, 2009 5:11 pm
I am certain Debbens do off-set sprockets.
http://www.debben.co.uk/
mayhem
Debbens
#3 PostAuthor: mayhem » Sun Jul 19, 2009 5:15 pm
wikkid mate cheers
#4 PostAuthor: Pigford » Sun Jul 19, 2009 5:51 pm
Debbens stock loads of 'em.... or try Talon in Yeovil :wink:
mick znone
#5 PostAuthor: mick znone » Sun Jul 19, 2009 5:52 pm
ok mayhem, put some pickies up when you can, welcome to the site :D
Redbeard
#6 PostAuthor: Redbeard » Sun Jul 19, 2009 6:18 pm
Welcome along mayhem, i'd love to see some pics of this chop mate.
1979 Z1000ST
london calling
#7 PostAuthor: london calling » Sun Jul 19, 2009 7:19 pm
I'm pretty sure that the ZZR1100 front sprocket has an offset as standard and are readily available to check for chain run clearance.
The ZZR is probably a 530 size,so the thinner chain should help.
Large offset sprockets put extra load on the output shaft.
Jack
mayhem
#8 PostAuthor: mayhem » Sun Jul 19, 2009 8:12 pm
I have the ZZR sprocket but it has no offset at all
mayhem
#9 PostAuthor: mayhem » Sun Jul 19, 2009 8:14 pm
prob not rite place to post this but can someone recommend a site i can put some pics so i can get them onto here
phil churchett
#10 PostAuthor: phil churchett » Sun Jul 19, 2009 8:24 pm
There is a thread in "Discussion Board" on how to post pics.
You will need a Photobucket account, which is free.
http://photobucket.com/
