Smoking
JohnJ
Smoking
#1 PostAuthor: JohnJ » Thu Jul 16, 2009 9:11 pm
My bike smokes intermittantly. Usually it's fine but sometimes when I stop at traffic lights it smokes. Grey smoke. Then I can do a mile or 2 and stop again and it's fine. The bike hasn't been used for years, the tyres have been on it for 5 years. It's done under 20k from new.
John.
dreadmanbastard
#2 PostAuthor: dreadmanbastard » Thu Jul 16, 2009 9:16 pm
wheres the smoke coming from? the exhaust pipe i assume.
JohnJ
#3 PostAuthor: JohnJ » Thu Jul 16, 2009 9:58 pm
Yes the exhaust. Funny really, not "Something to worry about" type smoke, more "Granny's car warming up" type smoke.
John
hillbilly
#4 PostAuthor: hillbilly » Fri Jul 17, 2009 6:04 am
do you do lots of little runs,it might help to ride it on a long run every now and then.to help get oil to proper running temp. :wink:
JohnJ
#5 PostAuthor: JohnJ » Tue Jul 21, 2009 3:23 pm
I've put a couple of hundred miles on it now, changed the oil and it still does it. Not as much though and not as often.
I'll stick with it I suppose!
toycollector10
#6 PostAuthor: toycollector10 » Wed Jul 22, 2009 5:39 am
If the bike has been sitting for a long time sometimes the valve stem seals stick to the stem. Then when the valves move the seals tear.
I saw a post from Jeff Saunders about this a while ago. It's a common problem with Zeds that have been sitting.
JohnJ
#7 PostAuthor: JohnJ » Fri Jul 24, 2009 3:42 pm
Sorted, thanks for replies, was the crankcase breather. Airbox has been removed and the breather rerouted. Was kinked.
John.
