Engine
kawadmb
If you want to get it out with the frame upright whip the top end off coz it's the only way you can get hold of the thing and make it light enough to lift.
Alternativelylay the bike on its side, after removing all but teh front and rear bolts and lift teh frame off the engine.
Either way taking the cam cover off will help coz there is very little clearance.
Hope this helps
Dale
Hope this helps
Dale
po
Strip the lot lay the frame with the engine on its off side and lift the frame off the engine , loads easier.
Ted
Ted
"Work this is why I did it"
"I've had more minutes than I have left"
Z1R D1
Granada
vantastic Transit........
KLE650
Z1R D1
Granada
KLE650
- rickman CRR
