Rear Plastic Inner Mudguard
martinz1b
#1 PostAuthor: martinz1b » Fri Jul 03, 2009 10:10 pm
Can anyone tell me if the earlier Z1/A/B inner fender will fit the later Z900A4 frame, I know there are subtle differences but if it is just cosmetic it doesn't matter to me.
phil churchett
#2 PostAuthor: phil churchett » Sat Jul 04, 2009 9:43 am
Fairly certain they are one and the same.
Z1000 A1/A2 look the same, but are slightly longer.
martinz1b
#3 PostAuthor: martinz1b » Sat Jul 04, 2009 9:50 am
I have only seen the Z900/1000 one in pictures, but the part that fastens to the very back of the frame next to the tail piece mountings looks like it could have a deeper ridge than the earlier one. I am not sure.
#4 PostAuthor: chrisNI » Sat Jul 04, 2009 10:57 am
The earlier ones are not the same as the Z1000 ones I have one here that is as has been mentioned a different profile to the Z1000 and is a different shape at the bottom - which if you think about it is logical because of the change fron drum to rear disc. I don't know if the Z900 is the same as earlier ones. This one has metal inserts around the hole, the Z1000 didn't have those obviously a penny pinching measure, and yes the holes can split on the later one proving that the inserts were a good idea.
This guard is surplus to requirements and is in reasonable shape it has a small hole part way down it, it doesn't fit my 1000 so it's not needed anyone any idea what it's worth or offers?
martinz1b
#5 PostAuthor: martinz1b » Sat Jul 04, 2009 3:59 pm
chrisNI wrote:This guard is surplus to requirements and is in reasonable shape it has a small hole part way down it, it doesn't fit my 1000 so it's not needed anyone any idea what it's worth or offers?
I just bought one for a tenner off Ebay but there are still some up for auction for £38. In the club mag they are £30.
hillbilly
#6 PostAuthor: hillbilly » Sat Jul 04, 2009 4:10 pm
i have one the same as that,Image
the second pic is one off my 73 z1
there is quite some differenceImage
