Alternator cover question
Jhenry
#1 PostAuthor: Jhenry » Sat Jun 20, 2009 3:20 am
I had some oil leakage from the grommet at the lower rear of the alternator cover. After draining my oil for an oil change, I pulled the cover, pulled the grommet, cleaned and degreased very well etc, and slid everything back into place with loads of the best goo I could find. Cleaned off the old gasket material, replaced the gasket with the addition of a light smear of sealant. OK. Worked fine at first. Then leakage. A careful examination tells me the repaired grommet is not the culprit. It appears to be coming from th gasket area right at the bottom. I can only assume the gasket tore or folded or something during the process and I did not catch it. My question is this. If I pull the cover to fix the gasket issue without first draining the oil, how much will I lose? A bit, a lot? Possible to do at all?
Steve Cooke
#2 PostAuthor: Steve Cooke » Sat Jun 20, 2009 4:57 am
Just lean the bike right over and you wont lose any.
mick znone
#3 PostAuthor: mick znone » Sat Jun 20, 2009 7:17 am
left mine on the centre stand for two weeks with cases off, lost about half a cup full.
Jhenry
#4 PostAuthor: Jhenry » Sat Jun 20, 2009 1:22 pm
Excellent! Thanks guys.
