Any ideas, my Zed has been running rough on tick over and up till about 1/3 throttle (well it seems ok after that anyway), I have traced it to #2 cylinder. I have swapped plugs, cleaned pilot jets and swapped leads, I have a good spark, obviously I can't guarantee that the pilots are cleaned properly as I have no kit, but before I start buying things I thought I would have a punt on here. Carbs are RS36's BTW, I have electronic ignition and have tried a mix of new and old plugs... What do you lot think.
Regards
Ideas
paulmceleney
- Chunks
Same thing
Hi
Just traced the same fault with my Z1R.
It was damaged manifold rubbers on 3 & 4
Replaced with new rubbers and clips.
Job done.
Good luck
Job done.
Good luck
