Ideas
BShaw
Ideas
#1 PostAuthor: BShaw » Wed Jun 10, 2009 4:00 pm
Any ideas, my Zed has been running rough on tick over and up till about 1/3 throttle (well it seems ok after that anyway), I have traced it to #2 cylinder. I have swapped plugs, cleaned pilot jets and swapped leads, I have a good spark, obviously I can't guarantee that the pilots are cleaned properly as I have no kit, but before I start buying things I thought I would have a punt on here. Carbs are RS36's BTW, I have electronic ignition and have tried a mix of new and old plugs... What do you lot think.
Regards
Baza
paulmceleney
Chunks
#2 PostAuthor: paulmceleney » Wed Jun 10, 2009 4:54 pm
have a look at your mainfold rubbers swap them over to see if there is any changes
StephenW
Same thing
#3 PostAuthor: StephenW » Thu Jun 11, 2009 7:19 am
Hi
Just traced the same fault with my Z1R.
It was damaged manifold rubbers on 3 & 4
Replaced with new rubbers and clips.
Job done.
Good luck
BShaw
#4 PostAuthor: BShaw » Thu Jun 11, 2009 11:52 am
Cheers troops, will give that a go... will be next week now before I get a chance... seemed odd though , good spark and wet plug.
Regards
Baza
floydsz1
#5 PostAuthor: floydsz1 » Thu Jun 11, 2009 5:14 pm
Baza, could be running weak on that cylinder. while its running squirt some wd40 around the rubber manifold and see if the revs rise, that indicates its drawing in air.
peter.
