Z1000J GPz1100
Steve H
Z1000J GPz1100
#1 PostAuthor: Steve H » Mon Jun 08, 2009 12:02 pm
Hi all, can anyone help? I have a GPz1100B2 with a Z1000J fuel tank (I bought it as a paint set as I liked the colour scheme) but the fuel taps are not interchangable (the J is a 2 bolt affair where as the B2 is similar to the Z900 arrangement) I only have one tap for the B2, My question is does anyone know if other fuel taps are suitable as I cannot find a Z1000J tap to fit. :(
P.s The bike is running carbs.
Any help would be gratefully recieved :D
#2 PostAuthor: Al » Mon Jun 08, 2009 12:19 pm
http://www.debben.co.uk/acatalog/Z1000J.html
Expensive but Debbens do a Pingel tap with a range of two bolt fixings listed for 1000J as well as the 22mm nut fitting.
Its £80 but then what would a second hand original cost and then figure a rebuild kit in to that at £30 or so.
Wemoto did the rebuild kits for original taps, dont know about current stock.
http://shop.wemoto.com/pictures.dyn?u=1914620qqq3690453
london calling
#3 PostAuthor: london calling » Tue Jun 09, 2009 2:03 am
Steve,I might have a 1000J fuel tap that you can borrow until you get sorted.
I'll check over the weekend and let you know.
Jack
big green bus
#4 PostAuthor: big green bus » Tue Jun 09, 2009 7:00 pm
gpz 750 will fit a J
Steve H
#5 PostAuthor: Steve H » Tue Jun 09, 2009 7:56 pm
Many thanks for all the replys, they are most helpful and Jack, if you do have one to fit that I may borrow
that would be fantastic, it will tide me over until you need it back or, hopefully, I find one that I can purchase.
Thanks again ... Steve
london calling
#6 PostAuthor: london calling » Sun Jun 14, 2009 12:34 am
Steve,PM sent :wink:
Jack
