Z550 Fast idle lever or complete carbs?
Buckle
#1 PostAuthor: Buckle » Fri Jun 05, 2009 8:08 pm
It's a long shot I know - but does anyone have one / any?
All of a sudden the run around wouldn't idle on choke - and low and behold (another) a bit has dropped off. It's the lever that opens the throttle slightly when the choke is pulled up.
Anyone?
Insert witty comment here.......
scott reid
#2 PostAuthor: scott reid » Sat Jun 06, 2009 9:28 am
What make of carbs are they? I may have an old, incomplete set of gpz550 h1 carbs lying about. I think they are keihins
Scott
Buckle
#3 PostAuthor: Buckle » Mon Jun 08, 2009 10:25 am
Hi Scott,
Thanks for the reply.
The carbs are Teikei I think - I don't have the bike here at the moment so can't check, but they are slide carbs and not the CV type which was fitted to later monoshocked Gpz's - if that helps with identification?
scott reid
#4 PostAuthor: scott reid » Tue Jun 09, 2009 8:07 pm
Ok, sorry I can't help. I hope you get the part you need.
Scott
Buckle
#5 PostAuthor: Buckle » Sun Jun 14, 2009 5:19 pm
Still looking - anybody? :(
