I'm needing to get some bits repaired on my Z900 A4 frame e.g rear indicator mounts straightened, rear brake lever shaft straightened, steering lock stop repaired, & side stand bracket repaired, steering damper bracket repaired, along with welding a PMC frame bracing kit into place. Looking for a good honest engineer to do the work & don't mind paying the going rate. Failing getting hold of someone in Scotland, then I will travel if neccessary to get the work done. All suggestions gratefully accepted as I wan't to make a start on my project.
Steve
Reputable/Good quality welders in Scotland
- ZedHead
welding
HI Flying scotsman im up in highlands i could do it for you if the logistics aren,t to extreme.
1000 posts reached that will do for me,over and out.been fun.
