z1000 electric problems
stephen lavery
- Regular Poster
just fitted new alternator 3 phase. and new combined reg/rec from zed power. but battery still not holding charge. plugs very sooty. new plugs and battery. the reg/rec is a straight plug in to original green block connector, black wire to earth, white to fuse. there is another separate connector two blue wires looping back into same connector one red going into small connector, dont know were this goes? carbs set, float heights ect. bike pulling strong but fouling plugs. i think its wiring or maybe ignition (boyer bransden fitted. got 14.5 volts when fitted new parts last week. but battery flat tonight. give reading of 11.8 volts. IM SURLY LOSING IT.
stevie the babarian
stephen lavery
- Regular Poster
