Piper 4 - 1
Thezedsintheshed
A bit later than promised but here is the info that I promised on the Alfa and Yoshi pipes
Alfa 4/1
Downpipe diameter 35mm
Downpipe Length 830mm ( to start of collector box)
Tail Pipe length 640 mm
Tail Pipe diameter 63mm
Baffle center hole 30mm
Baffle length 250mm
Yoshimura 4/1
Downpipe diameter 38mm
Downpipe Length 710mm ( to start of collectoe box)
Tail Pipe Length 850mm
Tail Pipe Diameter 70mm
Baffle Center hole 38mm
Baffle length 370mm
Alfa and Yoshimura pipes
Yoshimura Pipe
Alfa Pipe
Yoshimura Stamping on base of pipe
The photos are not the best , the battery went flat on the camera
so I will get a few better quality ones posted in the next few days.
Have got a few other obscure pipes here as well so I will try and dig them out and post the same info regarding the spec of them as well.
From memory there is a Sebring race pipe , a Bassani race pipe and an old Racer 1 pipe as well.
Alfa 4/1
Baffle length 250mm
Yoshimura 4/1
Baffle length 370mm
Yoshimura Pipe
Alfa Pipe
It's not broke , just in bit's for a while !
