SPEEDO & TACHO Overhaul
- DogsbolloxofZ1B
How do you remove the needles on these things? I've tried as much as I dare to pull them off, unfortunately can't seem to raise Chris Rivett any longer for advice.
Mike
Mike
- mick znone
Dogs, ive just tried pulling the needle off on a spares tacho, just to see how its done. the dial does come off the pin, but the pin snaped off the tacho on mine, then i removed the pin with pliers, so what im saying is, i wouldnt use to much forse until someone who knows what theyre doing gives some good advice.
paulmceleney
- Chunks
Try e- mailing Al Marshall. He completely renovated my set.
Outstanding workmanship.
- DogsbolloxofZ1B
Steve Cooke
- DogsbolloxofZ1B
