After a few taps the plug moved very easily and emerged out of the frame lug ( Too easily in fact and the donor motor was a minter, untouched from the factory when i got it )
And here it is.
A swift session on the lathe produced a slightly larger replacement which was duly fitted and everything was re-assembled.
I've now replaced the oil so i'll have to wait till the morning to be sure i've cured the leak ,Then i'll be a happy man again.
