Carb Balancing tools?
#16 PostAuthor: kev edwards » Fri May 22, 2009 2:00 pm
hello Bruce , mercury ones , your my best mate now. :lol:
I don't do mercury got poisoned by the stuff about 25 years ago very unpleasant , but there is an upside i am now eight feet tall in the summer, :roll:
Steve R
#17 PostAuthor: Steve R » Fri May 22, 2009 3:44 pm
Its ordered then :lol: Hopefully get them balanced before York rally :lol:
ROZZER
#18 PostAuthor: ROZZER » Sat May 23, 2009 6:51 pm
I use Mk 1 mercury gauges, not as convenient as the Mk2 stainless rod version but spot on accurate.
As for auxiliary fuel tank, made mine from an old gear oil bottle, y piece in fuel line for dual inlet on Z1 carbs - cost £2.
AKA John Roscoe. PUM #028
1975 Z1B, 2013 Z800
Garn 1
#19 PostAuthor: Garn 1 » Wed May 27, 2009 2:06 am
Steve R, thanks for the thread and the Carbtune web site. Inspired by the comments, I just ordered a Carbtune (4 tube) and a Colortune (single plug 14mm) from Mogan's. Let me know how you get on with yours. Postage was great to Australia (special rate for the promotion).
Steve R
#20 PostAuthor: Steve R » Wed May 27, 2009 1:03 pm
Hi Garn, mine arrived today, looks a good bit of kit may go and have a play tonight will let you know how I get on :)
#21 PostAuthor: chrisu » Wed May 27, 2009 4:59 pm
i have a done a 'how to use' spiel so if you want it pm me your email address.
#22 PostAuthor: chrisNI » Wed May 27, 2009 5:01 pm
chrisu wrote:i have a done a 'how to use' spiel so if you want it pm me your email address.
or wait until the next magazine it will be in that...
Steve R
#23 PostAuthor: Steve R » Wed May 27, 2009 8:05 pm
Have pmd you Chris Thanks.
#24 PostAuthor: chrisu » Wed May 27, 2009 8:28 pm
you have mail........
Garn 1
#25 PostAuthor: Garn 1 » Wed May 27, 2009 9:48 pm
ChrisU, I would appreciate a PM or e-mail on your "How to Use" speil on Carbtune and/or Colortune. RegardZ ~ Garn
e-mail,<garncook@ozemail.com.au>
#26 PostAuthor: chrisu » Thu May 28, 2009 8:05 am
morgan carbtune balaning - on its way.
Garn 1
#27 PostAuthor: Garn 1 » Wed Jun 10, 2009 5:36 am
Received my Carbtune & Colortune kits today.... Will let the forum know how it works out. ChrisU, thanks for the introductory "How to Use" info.
Steve R
#28 PostAuthor: Steve R » Wed Jun 10, 2009 8:33 am
Hi Garn,
I did mine the other day, the gauges are very good, mine were well out and getting them something like right has transformed the idle and quietened it right down at idle.
Point to watch, every time I adjusted and got them nearer to being correct the idle speed would rise and I had to keep backing it off on the idle adjuster that hits the linkage, what took me a while to suss was that I had to back it off so far that it was no longer touching and the carbs were being held open on the throttle cable.
I did not buy a remote fuel tank, just kept topping the float chambers up from the tank, putting on and taking it off again. This was a mistake and I have now ordered this:-
http://www.discovolantemoto.co.uk/works ... d_266.html
but see also on here, the home made one:-
http://www.z1ownersclub.co.uk/forum/vie ... php?t=9977
I also did not order the carb adjuster tool choosing instead to use a ring spanner and screw driver, again this was a mistake and I am ordering the proper tool before I have another go.
Will be interested to see what you make of the colour tune, I had one years ago when I used to mess with webbers on Lotus elans, lent it to someone that did not bother to return it, I think it was a pretty good bit of kit though, if you rate it I will get myself another one. My Z is nearly run in now and I want to get it as correct as possible before I get it set up on the Dyno.
Skunkwurcx
#29 PostAuthor: Skunkwurcx » Wed Jun 10, 2009 12:05 pm
I ordered the Carbtune Pro last week and hopefully it will be here today or tomorrow. It was highly recommended by folks on the ZX9 forum(also carbed) so for the price of a visit to a shop to have both the Z and ZX sorted, I'll now be able to do 'em myself. Added bonus is that the throttle bodies can be synced on fuelies. Morgan was out of the special carb adjuster for the Z when I ordered the Carbtune though :(
#30 PostAuthor: chrisu » Wed Jun 10, 2009 1:01 pm
ring spanner and a screwdriver works just as well........
