Won't fire up
Redbeard
Won't fire up
#1 PostAuthor: Redbeard » Wed May 13, 2009 5:58 pm
Evenin all, tried starting the ST earlier to do an oil and filter change but it won't start. Battery has plenty of power, starter motor spins, plugs are only a few weeks old, fuel tap working, plenty of fuel, carbs have fuel, no apparent blockages...Manual says could be defective starter motor clutch or a loose alternator rotor bolt, would either of these sound likely? Is this common? Was running fine just days ago, has always started 1st or 2nd go. Not sure what else it might be, any help much appreciated.
1979 Z1000ST
#2 PostAuthor: Rich » Wed May 13, 2009 6:43 pm
Does the engine turn over?
Does it start on Kickstart?
Is there a spark at the plugs?
hillbilly
#3 PostAuthor: hillbilly » Wed May 13, 2009 6:44 pm
any fuel in it,it has been known. :?? :?:
#4 PostAuthor: Al » Wed May 13, 2009 6:47 pm
Adam you have pm
Redbeard
#5 PostAuthor: Redbeard » Wed May 13, 2009 7:11 pm
Just going to check spark, theres enough fuel, spins over ok. i'll keep you posted.
1979 Z1000ST
Redbeard
#6 PostAuthor: Redbeard » Wed May 13, 2009 7:49 pm
She lives! Now I'm not sure how but I tried to start it normally again without success. I took the tank off to test spark, held plug to the block and pressed starter, spark was fine and it sounded like it fired. Did the same with a different plug, same response. Put tank back on and 2nd try she spluttered into life. Thats after a good 20 mins without a hint of life so I've no idea why this made a difference. Main thing is I'm back in business. Thanks for all your help though, overwhelmed by responses/pm's/emails. Brilliant stuff! :wink:
1979 Z1000ST
hillbilly
#7 PostAuthor: hillbilly » Wed May 13, 2009 7:54 pm
that sounds like a bad connection under tank,be aware of it doing it again.might be good idea to take tank off and wiggle wires while it runs.see if it stops.
Redbeard
#8 PostAuthor: Redbeard » Wed May 13, 2009 7:57 pm
cheers hillbilly, i will try that, i'll be taking tank off to fit new sender gasket soon anyway so I'll try it then.
1979 Z1000ST
tedsonthezed
#9 PostAuthor: tedsonthezed » Wed May 13, 2009 11:35 pm
Erm... Just a thought Adam. Bad connection. Spark. Petrol leak.
I'd get that gasket in soon.
You want how much?
#10 PostAuthor: PAULJAC47 » Thu May 14, 2009 3:10 pm
You say you took tank off not got a blocked breather in cap by a any chance??
Redbeard
#11 PostAuthor: Redbeard » Thu May 14, 2009 5:25 pm
All ok still, looks like it may have been a dodgy connection. Ordered gasket now too. Thanks all. :wink:
1979 Z1000ST
Users browsing this forum: Bing [Bot] and 15 guests
