Clutch Window
Jumbo
Clutch Window
#1 PostAuthor: Jumbo » Mon Jul 14, 2008 9:43 pm
I am considering making a window for my clutch cover. Has anyone got any information on what type of perspex is used and the thickness. I would think around 3mm would be OK.
Jumbo
LE to JOG on a z900
P.U.M.
Dark Skies
Re: Clutch Window
#2 PostAuthor: Dark Skies » Mon Jul 14, 2008 11:11 pm
Jumbo wrote:I am considering making a window for my clutch cover. Has anyone got any information on what type of perspex is used and the thickness. I would think around 3mm would be OK.
Jumbo
Perspex tends to warp when hot.
Thermoclear Polycarbonate Sheet might be a better bet - they use it for double glazing
KZ1000-M1 CSR
london calling
#3 PostAuthor: london calling » Tue Jul 15, 2008 4:34 am
Check out the Streetfighters MCC website
http://www.streetfighters-mcc.co.uk/
Jack
Murph
#4 PostAuthor: Murph » Tue Jul 15, 2008 12:19 pm
Try talking to Lex (streetfighter z1a) I think his bike has one fitted there are pic's of it in the Scottish bike show thread . :wink:
Z9A4, Z1170R, ZZR1100
Big Glenn
#5 PostAuthor: Big Glenn » Tue Jul 15, 2008 4:36 pm
Lexan is what you need I think, otherwise know as Polycarbonate.
ludders
#6 PostAuthor: ludders » Tue Jul 15, 2008 7:17 pm
Big Glenn wrote:Lexan is what you need I think, otherwise know as Polycarbonate.
I think i'v got some left from my race car window's, i'll have a look in the morning and let you know :)
z1a , z900 a4 , zx9r
Jumbo
#7 PostAuthor: Jumbo » Tue Jul 15, 2008 7:25 pm
Won the "donor" clutch cover from Ebay at £11.44 apologies if I out bid someone !
LE to JOG on a z900
P.U.M.
Steve R
#8 PostAuthor: Steve R » Tue Jul 15, 2008 9:34 pm
What race car Ludders?
ludders
#9 PostAuthor: ludders » Wed Jul 16, 2008 8:30 am
Jumbo i'v got sum 4 mm thick if you want it PM you'r address and i'll send you a bit :)
Steve R wrote:What race car Ludders?
The class is called Supper Silhouettes ,spaced frame chassis,kevlar body, vauxhall 16v 260bhp, 10" slicks and it weighs 700kg :twisted:
if you want to see a pic tell me best place to post and i'll try :)
ludders
#10 PostAuthor: ludders » Wed Jul 16, 2008 6:01 pm
Jumbo i'v just cut and wraped lexan,i'll send tomorow,should be with you friday,dont worry about postage, glad to help :)
chris
Jumbo
#11 PostAuthor: Jumbo » Wed Apr 29, 2009 1:54 pm
I managed to finish the window which became two in the end. Thanks to "ludders" for the Lexan and TLC for one of the covers.
LE to JOG on a z900
P.U.M.
#12 PostAuthor: Pigford » Wed Apr 29, 2009 3:52 pm
Jumbo....... that look very smart matey :twisted:
tlc
International Rep
#13 PostAuthor: tlc » Wed Apr 29, 2009 4:58 pm
Forgot I`d sent that to you.
Looks darn good......................................how did you cut it ?
Asphalt Cowboy
Jumbo
#14 PostAuthor: Jumbo » Wed Apr 29, 2009 5:26 pm
TLC - I machined them both initially on the lathe and then the second one I machined on the milling machine to follow more the shape of the cover especially the oil level window.
I was onboard one of the ships where I work hence the uniform !
LE to JOG on a z900
P.U.M.
#15 PostAuthor: Pigford » Wed Apr 29, 2009 5:29 pm
See who does most of the work..... NOT the immaculately turned out, clean & perfectly laundered b****d :lol:
