Oil leaking from tacho drive
dreadmanbastard
hi ,me again. Go a slow leak of oil from my tacho drive. It has been there a while but i had no tacho cable , i thought installing one (cable) would fix the problem but it hasent. its not from the seam made between the engine casing and the body of the drive it seems to leak out the tip, is it meant to for oiling the tacho cable? xept its dripping on my pipes which then smoke like a bxxxxxd. its going for mot soon aswell and id rather it was on top form. any ideas?? i tried instant gasket on the engine/drive seam.
wilsonsjw11
