its a single disc front brake on a z1a and it worked fine before i touched it
have a week off and feel a bit like all work and no play makes z a dull bike, to be honest
Steve R wrote:Mick, I am going to be doing this tomorrow as I have a new splitter to fit, that I have been polishing today.
When you say thumb over open end of master cylinder, where exactly do you mean?
Also when zed and other are talking about using a syringe, how big? and where do you buy one?
Steve R wrote:Thanks GB, I really want to do this tomorrow if possible.
Just to be 100% clear Mick, you had the hose off the master cylinder and put your thumb over where the hose would normally go? If this is hte case I guess with the air in the system the master cylinder was not priming, but when you had your finger over the hole where the hose went it created a vacumm for the master cylinder to prime against.
Thanks for the prompt replies!
