Z1000A2 Rear shock bottom rubbers
smeg918
#1 PostAuthor: smeg918 » Thu Apr 23, 2009 8:36 pm
Hi, Looking for the rear shock bottom rubbers/bushs (standard Z1000). Any of you's know where I can get a set, I've been told their no longer available so I'm hoping somebody can point me in the right direction.
zedtwo
#2 PostAuthor: zedtwo » Fri Apr 24, 2009 12:12 pm
Have you tried Z - Power 01942 262864 ? Better off phoning as not all parts they have are listed on Web , If thet don`t have them i feel sure they will put you right !
Mark Stratton
#3 PostAuthor: Mark Stratton » Fri Apr 24, 2009 12:41 pm
I might well have a couple in a box of spares that I have lying around in the garage. I will try to hunt them down and find out whether they are tops or bottoms.
smeg918
#4 PostAuthor: smeg918 » Fri Apr 24, 2009 1:17 pm
Thanks Lads, I'll give Z-power a call I was going to be ordering some stuff from them anyway, as you say if they don't they might know somebody who does. Cheers
smeg918
#5 PostAuthor: smeg918 » Mon Apr 27, 2009 4:58 pm
Well tried Z-power, no luck there have sent a couple of e-mails to other companys so will have to wait and see. might have to bite the bullet and get new shocks, just seems a shame to bin these.
Steve Cooke
#6 PostAuthor: Steve Cooke » Mon Apr 27, 2009 6:21 pm
I have some, I replaced mine for a pair of NOS that I had so I've got the old ones here which look reasonably good, if they will help pm your address and I'll send them to you.
smeg918
#7 PostAuthor: smeg918 » Mon Apr 27, 2009 8:27 pm
Hi Steven, Thank you for the offer, if you don't mind I'll wait and see if I have any luck from the company's that I've contacted. But if I still draw a blank from them I'll certainly contact you. I'm assuming your talking about a pair of shocks rather than just the rubbers.
regards smeg
Steve Cooke
#8 PostAuthor: Steve Cooke » Mon Apr 27, 2009 9:26 pm
No problem, I was referring to just the rubber bushes.
