rear shock mounting bush's Z1000A2
smeg918
#1 PostAuthor: smeg918 » Wed Apr 22, 2009 9:47 pm
Hi, quick query. are the shock mounting rubber bush's the same top and bottom. it's just the the rear shocks I've got on my bike are in great nick apart from the bottom rubbers are a bit ify, I've seen top rubbers advertised but not bottom. any help pleeeese.
compo z1r
Re: rear shock mounting bush's Z1000A2
#2 PostAuthor: compo z1r » Thu Apr 23, 2009 7:58 pm
smeg918 wrote:Hi, quick query. are the shock mounting rubber bush's the same top and bottom. it's just the the rear shocks I've got on my bike are in great nick apart from the bottom rubbers are a bit ify, I've seen top rubbers advertised but not bottom. any help pleeeese.
there diff'o mate and no longer available someone will have a set :?:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886
smeg918
#3 PostAuthor: smeg918 » Thu Apr 23, 2009 8:23 pm
Cheers Compo, Quess I'll post a thread in the wanted and see if I've got any luck. I'd get other shocks but it seems a waste to junk good shocks just because the rubber mounts have gone. Thanks for the help.
