I have a 78 model Z1r, said to have been imported to Uk from Italy many years ago. It had not really been used for several years, so checked it over, gave it a few runs, then serviced it. Apart from some brake work, its great...superb smooth tight quiet engine, I love it.
Came to adjust carbs at tickover, nos 1,2 & 3 all adjust well at about 1+1/4 to 1+1/2 turns out on air screw, but no 4 needs to be at about 3/4, and this cylinder sems weak in tickover contribution.
Thought I'd do a bit of careful adjustment of the metering screw underneath the front of the carb ....except there are NO screws in the holes.... looking with mirror, the holes look to have a small blanking plug pushed high up into them....I've never seen plugs in the metering holes before....has anyone else ? (I tried to put a metering screw in but the hole is definitely blocked because the screw won't even go in far enough to get near the thread starting.)
Z1r carbs, new one to me
He who dies with the most toys wins .
The z1r had an air screw above and to one side of the venturi and not an air screw below the front of the venturi, (unless I have mis understood your post). If not then I think the californian models had an anti tampering plug (like a brass cap) fitted for the tighter emissions controls, Regards, Steve
loz check mine out
Loz,
Get round to inspect my Z1R on sunday-mine is an Italian import also, so should have same carb type (you would expect so anyway).
The Z1000 brakes are much better today thanks for your assistance last night.
Reecy
Reecy
Reecy, I'll nip round at soem point during the week.
Steve, yes, the air screw is on the side, but the Z1R carbs are VM28SS model which also have the "do not touch" metering screw underneath.....or at least every set I've ever seen has had them before.
I guess the holes must be genuinely plugged, because without the metering screw in the hole, the running should be awful ( it isn't ) and there would be mixture fuel weeping out of the open hole in the bottom of the carb.
I have three UK z1r's, All with vm28's . None of which have fuel pilot mixture screws fitted or anti tamper plugs, Just the undrilled casting. All the 'Z' mikunis i have with this fitted are 26mm off either early z1/9 or later z1000a's with the superior fuel pilot circuit. Some Suzuki GS mikuni's have this but couldn't say specifically which except the 34mm 1000 katana's which i've fitted to my Z1R fighter. Anything with an anti tamper plug fitted is usually an import model.
po
Mine is also a Italian import and I have the normal Side mounted air screws as with any 28 mm`s.
Ted
Ted
"Work this is why I did it"
"I've had more minutes than I have left"
Z1R D1
Granada
vantastic Transit........
KLE650
Z1R D1
Granada
KLE650
Re: po
Yes. Most will still have the side mounted air screws and some will also have the fuel metering screws underneath. As Debben says. The anti tamper plug usually originates on american spec (i.e californian) machines to comply with their strict emmision laws and maybe this is also the case with the italian spec machines .Unless of course you have an american import that got shipped to italy then to the ukted1r wrote:Mine is also a Italian import and I have the normal Side mounted air screws as with any 28 mm`s.
Ted
Users browsing this forum: Bing [Bot] and 18 guests
