think youre right there davy it looks very much like a H****a item 500x4 or 550
garn hope this of some help mate
Z1 Brake Lever (Arm) - Differences in this small arm.
- z1bnackerkwacker
- z1bnackerkwacker
Well, looks as so you guys have nailed it. It appears most support the answer that the curved brake lever, is from a Hondx 550 or 500. Also it has been confirmed that the splines were identical (Hon & Kaw)
....Wait, late entry, it could be off a GPZ 500. We should be able to check that!
Thanks for you help and interest .....it's not a Z1!
Z1backnacker', I can't seem to find the number for the early Z1 with the head of the bolt to the front. The number 42029-033 you quoted is also for a Z900A4 (head to rear). Maybe Kawasaki didn't change it's number for this item.
- z1bnackerkwacker
Your best bet is to E-mail: info@z-power.co.uk they will be able to supply you part as well if available..Quote: from Garn 1 on 6:39 am on May 22, 2006
- Bruce Sexton
