Desperate to identify these !!!
I have sets from both z1r and 1000a .Both are identical externally as yours with idle adjuster underneath but z1r's are 28mm and 1000a are 26mm. I also have sets from gs1000 which are basically the same mikunis but have provision for idle adjuster on top and cable operated choke. Jetting sounds about right. Std Z1R 28mm has 112.5 mains and 17.5 pilots. So yours are probably 1000a 26's . As long as it runs ok why worry.
carbs
defo 28.mm z1r carbs
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886
Z1OC # 886
