Valve Timing
Valve Timing
Just replaced the head gasket on my z1000A1, but now bike wont start. Timing mark on the exhaust cam sprocket in manual shows a single mark which should correspond to a pin in the cam shaft. But mine has a mark either side of the sprocket which correspond to teeth on the sprocket. So these cams maybe replacements. Could it be that I have the exhaust can 180 degrees out ? Have good spark and fuel.
Chris
Chris
If you turned over carefully by hand....... should have felt contact.
If kicked or electric start..... may not have noticed if only just touched.... but enuff to bend valves.... I know... been there, dun that, got the T-shirt & bill
That is worst case senario, so probably not that bad
Is there compression on all 4 cylinders
Compression very low, 1 - 30psi, 2 - 30psi, 3 - 0psi, 4 - 25psi.
In the diagram above where it shows the timing mark level with the top of the head on the exhaust cam sprocket, mine has a continuous line right across, so you don't know which way round it should be. The marks also match to a tooth rather than a pin in the cam chain. I know that I should have checked and marked the positions before removal, but assumed they were standard as in the diagram.
chris
chris
From memory, as you look at the end cam lobes, they are either both facing in or both out (on a horizontal plain)
That is low... but I'd expect 0 psi if valves bent, so may just be cams out.... or valves only just touched... still f**ked though if they did.
Need to establish true valve timing before weeping/praying/drinking...
Pigford, cheers for the info, will take the cams out and review, suppose I can't tell if I have actually done anything to the valves unless I remove them. Suppose I can reset as you suggest, put back togther and see if it starts.
I can't believe you bent valves as you seem to know all about this sort of stuff.
thanks
Chris
PS Anyone replaced cams with ones with timing marks that sound like mine ?
thanks
Chris
So does anyone know how to set up the valve timing in the absence of timing mark 4 as shown in the drawing above on the exhaust cam sprocket ?????
I understand that when 1&4 cylinders are at TDC (T mark) then this is the rocker position, from which point rotating engine forward cylinder 1 exhaust should start openening but rotating back cylinder 1 inlet should just start opening. How do I know when this point is and from where to count the 28 pins in the cam chain??
Any help much appreciated.
Chris
Chris
