Maintenance Free Battery
Skunkwurcx
#1 PostAuthor: Skunkwurcx » Mon Mar 30, 2009 8:48 pm
I'm pretty sure the battery has gone the way of the DODO in the Z. It rolls over okay after a good run, but anything less than a 10 minute run at speed and it is very slow to roll over.
I've ordered up a maintenance free battery for it, but before I buy it I want to ask if they are okay for our bikes. It seems to me I read somewhere that they are not okay for them, but I can't be sure, and I also can't remember why if indeed they aren't.
Can anyone set my mind at ease one way or the other ?
Ta,
Andrew
edit : '77 Z1000 btw...thought it was in my sig :D
#2 PostAuthor: Pigford » Mon Mar 30, 2009 8:58 pm
I've got an Odessey dry cell battery which had a got cold cranking rating (essential for starting) and although not on bike long.... seems OK :wink:
Skunkwurcx
#3 PostAuthor: Skunkwurcx » Mon Mar 30, 2009 11:07 pm
Thanks mate, I guess I'll give it a go.
mick znone
#4 PostAuthor: mick znone » Tue Mar 31, 2009 7:00 am
maintenance free, is that the same as a gel battery? sorry for the ignorance. i have to buy a new battery for my bikes reamergance in 2 weeks time[ but want to buy a good one]. didnt want to buy a gel batery as have read that they need to be bigger??? :fly
outlaw
#5 PostAuthor: outlaw » Tue Mar 31, 2009 6:20 pm
i had a Odessey dry cell battery on the vmax that i had and it was far better at starting it when it was hot, ( max,s are a b#gg#r to start when hot ) i sold the bike and it had been on for 4 years and still spun it over as fast as the day i bought it,if the z need a bat that is the one i would buy again,
john
Pasc
#6 PostAuthor: Pasc » Tue Mar 31, 2009 7:34 pm
Mick, maint free isn't the same as a gel battery. A maint free battery is usually just sealed so you won't need to top up with acid occasionally. Hope this helps.
ps reading some of your thoughts and posts I'd say you've possibly topped up your acid enough already. :)
mick znone
#7 PostAuthor: mick znone » Tue Mar 31, 2009 9:20 pm
thanks Pasc, yes that answers my question, im going to look into maintenance free, i like the sound of that.
you're right about the acid, oh yes :lol:
z1000Chris
battery
#8 PostAuthor: z1000Chris » Wed Apr 01, 2009 6:44 am
Another advantage of a maintenance free ( sealed type battery ) there's no breather pipe and top up caps so therefore less corrosion around the battery area :D p.s Does the Odessey battery fit in the battery box properly ?
Skunkwurcx
#9 PostAuthor: Skunkwurcx » Wed Apr 01, 2009 11:34 am
I forget the brand name of the battery that my dealer ordered, but it supposedly has 30% more cranking amps than a normal one, and it is also $30.00 more that the maint. free batt. that I put in the ZX9 a few weeks back - just goes to show, nothing is free !! not even a few amps. :roll:
I'll post when it's in the bike with name and fit and all that.
mick znone
#10 PostAuthor: mick znone » Wed Apr 01, 2009 5:52 pm
wemoto do a maintenance free battery for the z1a but say make sure your bike has a good enough charging system to cope, otherwise the battery will fail????? what does that mean???? £39 +delivery
#11 PostAuthor: Pigford » Wed Apr 01, 2009 6:57 pm
Mick, the Odyssey batter is about £75 :|
Get wot you pays for though :wink:
mick znone
#12 PostAuthor: mick znone » Wed Apr 01, 2009 8:51 pm
Pigford wrote:Mick, the Odyssey batter is about £75 :|
to right Piggy, do you know what they mean by needing a charging system that can cope??? i have the impression the m f batteries are higher powered, am i right?
Steve Cooke
#13 PostAuthor: Steve Cooke » Wed Apr 01, 2009 9:05 pm
You can buy a Yuasa for forty quid, tried and tested.
#14 PostAuthor: Pigford » Wed Apr 01, 2009 9:16 pm
Yuasa are good, but I wanted the flexibility of mounting in a different orientation. Also, coz I don't use the bike thru winter the abililty to hold charge for a long time was important. Also I love all things technical & soopa doopa :twisted:
http://www.odysseybatteriesonline.co.uk ... ctspec.php
I got a PC545 for the Lawson, but I think a PC310 is for Z1000's :?:
mick znone
#15 PostAuthor: mick znone » Wed Apr 01, 2009 9:22 pm
yes pc310, can't find the price though.
Users browsing this forum: Bing [Bot] and 18 guests
