Been quite busy 'Pimping' (as the wife to be would say!
) over the last few days. First thing was to remove the 'twin' headlights & remove copious amounts of masking tape. That exposed the work of one of the
12 previous owners!
I can only describe it as the
'Loom of Doom'. Some fecker has cut of all the block connectors & replaced them with these blue Micky Mouse connectors, half of which fell off on thier own accord
I have replaced some of these as a temporary repair, as I plan to fit a new loom, from my spares stash during the winter rebuild.
I have worked out why the brake's are so sh*te.............. There is next to no disc left.
Fortunately, I have found an almost new set on one of my 'other' bikes, mileage shows 58k, so they must have recently been replaced.
Picture shows one still attached to the wheel, this one is rusty, the other was covered in oil (an attempt to move the bike with seized brakes I think), anyhow, both have been through the parts washer & once dried will get a little tickle in me bead blasting cabinet.
Here is a pair of wheel's I have scrubbed up, the camera
does lie!
I plan to get the tyres removed tomorrow, then I can blast the rims & repaint, probably get Mikey to do a bit of his magic too. Normally I would send these of to be powdercoated, but I need a quick fix for the ACE, I'll probably use these on the other GPz I put together from the bits left over.
Last pic is of my bodywork, which is pretty good. I will fit this for the Ace/summer then prob have another set repainted as new & keep this set fot the No.2 bike.
