Blueing of pipes
Dodgy Z1B
Blueing of pipes
#1 PostAuthor: Dodgy Z1B » Mon Mar 23, 2009 7:56 am
The middle two downpipes are blueing up but the outer two arent does this suggest carbs are out of balance or just thinner chrome :)
#2 PostAuthor: Pigford » Mon Mar 23, 2009 10:14 am
Hmmmmmm, centre pots always run a bit hotter.... It's not unknown for #3 & 4 to run on slightly larger jets in the racing arena :wink:
As this is tied in with "coils" too, best to double check timing :!:
GEZ635
#3 PostAuthor: GEZ635 » Mon Mar 23, 2009 4:37 pm
Most of the repro pipes I have used tend to blue a little . Never have the problem with my original pipes with the thicker downtubes. Bluejob polish does a great job of getting the blue marks off if its any help
Gez
#4 PostAuthor: Rich » Mon Mar 23, 2009 5:57 pm
The originals were probably double skinned.
Piggy - 2&3 are the middle ones :wink:
#5 PostAuthor: PAULJAC47 » Mon Mar 23, 2009 6:16 pm
Hi i would try a gunson colourtune to see if all the pots are burning the same,
Do the centre two plugs have a different clour to the outer two? Cheers Pauljac...
mikey
#6 PostAuthor: mikey » Mon Mar 23, 2009 6:58 pm
PAULJAC47 wrote:Hi i would try a gunson colourtune to see if all the pots are burning the same,
Spot on mate maralyn done my A2 with a colour tune yesterday as my No 1 exhaust was blueing more than the rest and it was running a tad lean thanks for that by the way paul.
AL MARSHALL
blueing
#7 PostAuthor: AL MARSHALL » Tue Mar 24, 2009 10:11 am
hey dodgy....if you try a bit harder you should be able to blue the outer ones as well :lol: :lol:
trouble.......seek and ye shall find
www.z-clocks.co.uk
Steve Cooke
#8 PostAuthor: Steve Cooke » Tue Mar 24, 2009 9:40 pm
Yeah get them all to blue up they look much better. :)
mikey
#9 PostAuthor: mikey » Tue Mar 24, 2009 10:01 pm
Least it shows the bikes being used
