Special tool ?
sparky650
Special tool ?
Hi all , a friend of mine is in the process of fitting new fork seals for me on the 650 but has come to a hault . There is a star shaped socket inside the fork tube that needs to be held from spinning to undo the allen bolt in the bottom of the fork leg/s . Every thing has been tried, the old broom stick down the tube and even a shaped piece of metal but we cant move it ? Any ideas what else we can use or will we have to go to kwak and borrow the special tool to fit ??
sparky650
- mick znone
Bobs yer weird uncle, never left alone[ are you sure now Pasc, really sure, if you need to talk, ive been through a lot of therapy, im always there if you need to talk mate
sparky650
use a brush stale cut at one end to 60 deg angle use to jam dowm inside leg to wedge nut this had worked for me give it a go Cheers Pauljac...
- london calling
sparky650
Cheers folks , that will be one or two things to remember the next time but i had to get the thing apart as a mate of mine is doing the work for me and wanted the froks back soon as poss. So i took them to the kawasaki shop and they were undone in a jiffy with the special tool . Mind you they were tight though , even with the special tool he was struggling a bit
