Engine assembly
Engine assembly
Right finally going to get round to putting the top end of my engine back together this week, apart from chucking loads of nice clean oil over everything as I hammer it together, do I need to use any thing else on the engine internals?
If Steve Smethurst has cleaned them, then I would not worry about it.
I have cleaned them by removing the brush from my parts washer & just pushing the hose onto the oilways, flushing them with cleaning solvent, then a bit of compressed air to finish 'em off.
Some of the oilways are 'blind' which are harder to flush, but like I said, if Steve Smethurst has done 'em, then you've got nothing to worry about. Good luck with the rebuild.
Ginger Bear wrote:If Steve Smethurst has cleaned them, then I would not worry about it.
I wouldn't be so sure about that, i've recently been working on a set of carbs that where cleaned by him and although they had a great finish to them they where found to have quite a bit of shite still inside them, we had to clean them again and put them through an ultrasonic bath again. In fairness he was willing to take them back and redo them and i'm sure it is not the usual result of his work, but the fact remains that you cannot take anything for granted.
- Mark Stratton
Had my engine and carbs done by Steve Smethurst and must admit did not find a spec of crap anywhere. Top finish but its just a shame that it does not stay the same for long.
Anyway Steve it sounds like your a bit of a whiz with the carbie things so seeing as you just done the road from me I might be cheeky and ask a favour in the near future.
